- Mute
- Permalink
- Report
Bug? wont post
tried top post some code and i get the error below. all the opps are ok apart from unsing a incorect tool for the facing operation (chamfer mill wich worked ok in other posts) and simulation is ok.
How do I track down the error?
Information: Configuration: Generic FANUC
Information: Vendor: Fanuc
Information: Posting intermediate data to 'E:\cad\nc post\172.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, June 28, 2017 4:02:33 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41304
Configuration path: C:\Users\landslide\AppData\Local\Autodesk\Autodesk Fusion 360\HMEPQE6QG4KT\W.login\M\D2017042573330276\CAMPosts\fanuc.cps
Include paths: C:\Users\landslide\AppData\Local\Autodesk\Autodesk Fusion 360\HMEPQE6QG4KT\W.login\M\D2017042573330276\CAMPosts
Configuration modification date: Tuesday, April 25, 2017 4:02:20 AM
Output path: E:\cad\nc post\172.nc
Checksum of intermediate NC data: 7f3825538983e85fe38b4665eac2bb1e
Checksum of configuration: 697ff9fa715c6107aab51dd73dd492bf
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3174
Error: The depth is invalid.
Error: Failed to execute configuration.
Stop time: Wednesday, June 28, 2017 4:02:33 AM
Post processing failed.
- Mute
- Permalink
- Report
found the problem by supressing each operation one by one and trying to post.
the 8th operation was a spot drilling op doing two hole sizes.
moved the different hole size to a new op and it posted
- Mute
- Permalink
- Report
More accurately you likely had either the retract or feed height set lower than the one that is supposed to be above it.
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Fusion
