kellings
250 Views, 1 Reply
Laser/plasma/Waterjet best practice
When cutting the different contours on a part, can you choose all the closed loops in one operation or should you create an operation for each closed profile?
Is this a matter of personal preference? I would think doing things individually would give more control for things like entry points. As I'm fairly inexperieced in this process, I'm not sure if that is a big concern though. I've attached a picture of a part that is 5" x 5" with some internal features.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
