06-24-2017
07:16 AM
- Mute
- Permalink
- Report
06-24-2017
07:16 AM
Just looking at your contour op, you are misusing model selection in the op. Model selection should only be used to add surfaces to the model selected in the setup, if you just select some surfaces like you have the op will not see the rest of the model and you run the risk of toolpaths going through the rest of the model. To confine the toolpath use boundaries or touch\avoid surfaces.
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
