- Mute
- Permalink
- Report
Turning Heights - From Selection now working correctly
When using from selection for the inner height there seems to be some issues. As you can see in the attached image I have from selection and the inner radius indicator is not showing correctly.
- Mute
- Permalink
- Report
Have you selected the model on the setup, just came up in another thread and I though you might have the same problem
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
Thanks I just double checked and there body is selected in the setup. So not sure what is up with it.
- Mute
- Permalink
- Report
Can you attach the file it's a bit difficult to see quite what the part looks like in the picture.
Mark.
Mark Hughes
- Mute
- Permalink
- Report
It looks like some of the options for ID don't work. If you have a hole through the part and select Model ID it picks that up ok.
But using selection just picks up the model ID and ignores the selection.
Mark
Mark Hughes
- Mute
- Permalink
- Report
Also grabbing the manipulator and dragging when in from selection mode does not work correclty. When I drag up it get goes down and dragging down goes up.
- Mute
- Permalink
- Report
Fusion
