copypastestd
in reply to: jeff.pek
That problem with some parameters with large help popup window.
There are on my screencasts:
On my screencasts it's a Passes > Direction and Passes > Tolerance and Passes > Stock to Leave > Axial Stock to Leave (for Face strategy).
But the same problems will be for all other strategies, with same parameters.
Another "bad" parameters, with same behaviour:
Heights > Retract Heights > From
Heights > Feed Heights > From
Heights > Top Heights > From
Heights > Bottom Heights > From
Passes > Smoothing
Passes > Minimum cutting radius
Linking > Ramp > Ramp Type
It is not full list, such problem parameters about several dozens.
