martin.dunschen
Hi @Anonymous
In my experience you can use either 2D or 3D adaptive in the example you're showing. The difference is that for 2D adaptive you have to select the contours you want to clear out, and in 3D you just need to select the actual model, and check that the top of the stock you are using coincides with the top of the model. But if your pockets all have different depth, or are sculpted at the bottom and/or have tapered walls for example, definitely use the 3D Adaptive.
Hope this helps.
Martin
