ovisopa
in reply to: twistedlabel
I don't know what surfaces/contours you have selected for your pocket, but even the adaptive it seems to hit your upper section of the fidget.
But about the 2D pocket that mills the lower section of the model, it seems the green toolpath hits your model, that is the lead-in/lead-out toolpath, check your setting in the LEAD IN section, in LINKING tab maybe you can make it retract directly up, or leadin/lead-out in another section of your fidget.
I think if you export your model and attach it other users could help you, it will be much easier to find a possible solution.
