1283 Views, 9 Replies
Chamfer does not generate G41/G42 cutter compensation
I have to chamfer the hole using chamfer operation. At Passes tab for this operation there is a Compensation Type option.  I have selected " Wear" but the code generated does not have G41 G40 compensation.  Is it bug or I am doing something wrong.
I have attached Fusion file.
Marek
Steinwerks
I believe this is a bug and 2D Chamfer doesn't use wear compensation. Tried it in an entirely different part with completely different geometry and wound up with the same result. You can use 2D Contour though, using the Chamfer checkbox on the Passes tab, and wear compensation is working correctly.
@fonsecr could you confirm this?
Edit: I got the same result using 2D Chamfer in HSMWorks 2018 R1.41862.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
in reply to: Steinwerks
If this is bug, should it be reported to somebody?
Steinwerks
I tagged a developer in my previous post to get his attention hopefully. I feel like this has been around for a while so perhaps we'll get some insight.
Neal Stein
Find me on:
fonsecr
Thanks. An oversight on my behalf. I opened ticket CAM-7448 to get this one supported.
René Fonseca
Software Architect
soldfather
in reply to: fonsecr
I've been seeing the same issue.  This thread has been silent for a while now.  What was the end result?  Fix or no fix?
slickmilwaukee
in reply to: soldfather
Still having the same issue. NO G41/G42 with chamfer. Why is it in the drop-down and available to choose if it's not going to work? Is this ever going to be addressed, or am I just missing something??
303Michael
I came looking for a missing G41 in my code and apparently, this is still a thing 5 years later.
tommi91CLFY8
still not fixed?
DarthBane55
in reply to: tommi91CLFY8
Hi, there is actually nothing to fix.  Read thru this:
https://forums.autodesk.com/t5/hsm-post-processor-forum/2d-chamfer-and-cutter-comp/m-p/11719963#M306...
Actually, you can skip to the last few answers.
