HughesTooling
in reply to: fishtruk
It does normally work but if you're using adaptive it's not a finishing op so small changes might not affect the size, that's why I asked what type of op you're using.
Does the g code look different if you change the stock to leave and what tolerance have you set in the op. All hard to guess what's going on with no real info like a file.
Mark Hughes
Owner, Hughes Tooling
