fishtruk
in reply to: LibertyMachine
Are you saying the Stock to Leave box doesn't work in pocket?  The path is calculated based on the pocket perimeter, the size of the tool and the Stock to Leave box I thought. G41 isn't used unless I tell it to.
When I do a tight tolerance hole, as this for a sprue bushing I thought I had always used a negative number in this box to open the hole up as needed.
I was going back and forth, a few tenths at a time to no avail, then used layout fluid to find it wasn't doing anything except scuffing the blue off when I wanted .0003"
Thanks, I'll investigate further tomorrow. I've been wrong before :winking_face:
