in reply to: Mike.Grau
Anyone have a workaround for chamfering before parting off yet? This is one thing that keeps us from using fusion for real production runs as when we edit posted code It opens the door for bad stuff....
What I want to do is add a small chamfer on the back of a part with my parting tool and then part off. I have "rigged" it using the chamfer tool but the problem with that is the direction of feed is running up and to the front of the part... (not going to get a good cut like that) If you could change the chamfer command to work "from front to back" I think it would work.
Ideas?
