04-23-2017
11:19 AM
- Mute
- Permalink
- Report
04-23-2017
11:19 AM
I believe the simulation time takes the default rapid speeds and toolchange time, not the one you specified... if you change the times in the setup sheet post you should get the same output.
There is nothing wrong with the calculations in the setup sheet post, open it and look for yourself.
You must also think about the machine accelleration and jerk speeds... This will have an impact and will not be in the calculations (would be different for every machine and cause confusion for most users).
In your example, how long did it actually take to machine?
Fusion
