Steinwerks
in reply to: Steinwerks
Your post isn't set up for the threadmill and fails: "Error: UNKNOWN CUTVIEWER TOOL TYPE: 38"
Your .log files should be located here (possibly in a subfolder, this one was in '3'): C:\Users\*username*\AppData\Local\Temp\Fusion360CAM
I suspect that the file open command isn't getting to Brackets fast enough. If you can change the editor to the HSMEditor.exe, I would suggest it. It's much better at catching those commands and launching in time.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
