282 Views, 3 Replies
Minor Fanuc post editting needed.
I need some minor changes done for my fanuc post, I am having a lot of trouble getting 'Flood and through' coolant to work. I basically need M8 (flood coolant) and M7 (through coolant) to be posted on separate lines of code, otherwise it only activates the first one.
Thank you very much, I've attached a copy of my current post.
ivan.stanojevic
I have simply used the code from Haas generic post and implemented into your post.
So now, when you choose coolant "flood and through tool", it will output M08 and M07 on two separate lines.
Ivan Stanojevic
in reply to: ivan.stanojevic
I cannot thank you enough, that's awesome! Thank you!
ivan.stanojevic
Smiley Happy cheers
Ivan Stanojevic
