1942 Views, 17 Replies
selecting a tool
I am trying to set up the 2D Face mill step tgo mill the faces of the workpiece.  I was planning to use a .5 inch dia., 2 inch long 4 flute flat endmill.  But when I select tool and try to give these dimensions to an endmill, everything behaves correctly, but the tool shows up after OK as #1 - O0.2031" flat.  What am I doing wrong.
jeff.walters
Can you export the file as an .f3d and post it here or email it to cam.support@autodesk.com?  I'm not getting the same thing on my part.
Jeff Walters
Senior Support Engineer, CAM
in reply to: jeff.walters
Here's the f3D file.
jeff.walters
clayton
I have tried it and do see a strange looking tool but once I set it as you said it stays. I have tried it on 2 pcs and a MAC. Has this happened again?
Jeff Walters
What do you mean "strange looking tool"?  I just get a hang.  Repeatedly.
jeff.walters
the cutting diameter is smaller than the shank diameter and an odd decimal number.
Jeff Walters
thanks.  Unfortunately the only PC that I have that runsFusion without hanging is in the shop.
I am trying to select a 1/2" diameter flat end mill, and when I do, I get an error: "Error: Internal CAM kernel error. Please report through your support channel."
How do I change these?  I see a tool library, but nothing in it matches my 1/4" shank, 1/2" diameter, 2" long, 4 flute end mill.
att's odd because I am using tools from your libraries.  See attached screen failining with "no toolpath" complaints.  What am I doing wrong?
jeff.walters
The first problem I see is that you don’t have a model select in your setup. The next is that your geometry is showing something select but I don’t see it on the part. Could the edges you selected have been removed from the part?
Once I selected the model and new geometry the Adaptive operation generated.
Jeff Walters
Thank you.  I was able to generate gCode.  I am now on to my next problem.  The Sherline post processor produces gCode that specified a tool not inh the EMC library, so I added it, and yet the simulator refuses to run ith it.  On the LinuxCNC forum, another user said that I should use the generic EMC postprocessor.  When I tried that I received the attached error log.
I specified Generic EMC for post processor and received this error log:
Information: Configuration: Generic Enhanced Machine Controller (EMC)
Information: Vendor: Autodesk, Inc.
Information: Posting intermediate data to 'C:\Users\clayton\Desktop\vhalgen.ngc'
Information: Total number of warnings: 1
Error: Failed to post intermediate NC data.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Wednesday, July 22, 2015 2:26:31 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 39126
Configuration path: C:\Users\clayton\AppData\Local\Autodesk\webdeploy\production\76be329ccfa969e6cd7c65a58d520471a18c0052\Applications\CAM360\Data\Posts\emc.cps
Include paths: C:\Users\clayton\AppData\Local\Autodesk\webdeploy\production\76be329ccfa969e6cd7c65a58d520471a18c0052\Applications\CAM360\Data\Posts
Configuration modification date: Friday, May 29, 2015 3:44:06 PM
Output path: C:\Users\clayton\Desktop\vhalgen.ngc
Checksum of intermediate NC data: d4121ca196ddf75121e849c672b3ec26
Checksum of configuration: 165e192f1bd9c593ed219c71a7a0484d
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2014 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.1517
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, July 22, 2015 2:26:31 AM
Post processing failed.
jeff.walters
This is normally cause by not working on the setup XY plane and using a non-rotary post processer. Do you have an operation that is using Tool Orientation?
Jeff Walters
Not  to my knowledge am I using a Tool Orientation.  Where would this be appearing?
What is a non-rotary postprocessor?
When I run simulate, I see my end mill coming in from the side on one face, where all the other mills are coming from Z.
jeff.walters
than thats the operation that is causing the error.
Jeff Walters
If you look at http://www.linuxcnc.org/index.php/english/forum/38-general-linuxcnc-questions/29441-tool-question?st... and look at NitroCH3No2's response of
22 Jul 2015 00:24, he seems to have identified the cause of the hang.
