- Mute
- Permalink
- Report
I want to use a 2D contour to cut a selected contour with my drag knife.
Since there is no drag knife tool in F360 I use a 2mm flat mill to simulate my drag knife.
The problem I have now is my drag knife must cut in the center of the contour and not inside or outside.
F360 always uses the diameter of the tool and correct the path to cut exactly inside or outside of the contour.
Is there any way to say F360 to cut in the middle if the contour and not inside or outside?
Hope it is clear what I mean.
Thanks for any help!
- Mute
- Permalink
- Report
On the passes tab set the offset type to off.
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
@HughesTooling: Thanks a lot for quick answer, in the meantime I found it by myself.
just to make it clear for someone who needs this feature as well it is 'Compensation type' (not 'offset type'):
- Mute
- Permalink
- Report
Fusion
