bmxjeff
541 Views, 9 Replies
Undercutting & Checked Geometry
Hey guys,  I can't remember but, has Undercutting always avoided the Geometry  "Under" the checked Surfaces?
In this image, the Little sliver of a surface I selected as Checked. So, it avoided every thing under that surface too.
Basically, I can't cut Under a checked surface? I thought I could at 1 time. Maybe not. Thanks!
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
LibertyMachine
in reply to: bmxjeff
You should be able to get there... Any chance you could share the file or invite someone to it so I/We/They can play around with it?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
bmxjeff
in reply to: LibertyMachine
Seth,
I thought so too! I've see this behavor for the last 2 years, I think. I can't remember if it has always been that way. I guess I could find an old model and re-generate the code.
Thanks!
Jeff Hooper (Owner)
LibertyMachine
Ummmm.....
I did nothing to it. But it appears that it's doing what you are looking for:
Seth Madore
bmxjeff
I got a path that will work, but If I didn't want the tool to touch the top, I can't select them as Checked.
Jeff Hooper (Owner)
bmxjeff
I'm such a CAM snot. But I drink Folgers coffee. "Not a coffee snot"
I checked the older one. I just used Slope and a boundary. Actually, back then.... there was no "Checked Geo" option yet in Fusion. : ) It's come a long way!
Jeff Hooper (Owner)
LibertyMachine
Even though you have something that works now, I flipped it around and selected everything I wanted to cut (the Touch part in Avoid/Touch):
Seth Madore
bmxjeff
Nice! I'm trying to do that but the path keeps failing to generate. I honestly have not thought of using "Touch" like that. That will save me some work.
Thanks man!
I have no idea why this post says it needs an answer. : )   Must have hit the wrong button in an email.
Jeff Hooper (Owner)
LibertyMachine
Here's your file back. I selected the faces I wanted to cut, ticked the "Touch" box and that's all she wrote
Seth Madore
bmxjeff
Thanks again Seth! I find it interesting that Checked Geo doesn't work with undercutting but the Touch option does.
Back to my Folgers.
Jeff Hooper (Owner)
