LibertyMachine
1) You've run g-code produced by other software, with success, on this machine? What was the software used
2) nothing much to say here
3) What value are you inputting? Half the tool or full diameter? For Control Comp, you should be inputting half the tool. Of course, this is just me assuming that the Fanuc on your machine is configured much the same as all the other Fanuc's I've encountered
In the .f3d that you provided, which Setup is causing you grief? ( a side note; the setup on second op isn't center of the part, but center of the recognized stock)
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
