aniffenegger
in reply to: Steinwerks
Yes, it did it every time we ran the code. We ran it through single block and it worked, though. The reasons we came up with were:
1) Rapid motion too high (F500 was brought down to F450, no change).
2) Controller starved of data (Not the case here, unfortunately).
3) Too many small movements causing a blockage for the Haas (Still not sure).
4) Something concerning the diameter of the tool (1.000" Insert Mill).
5) Fusion-related (Again, not sure).
I'm not sure if you saw my post before this one, but changing the tolerance for the smoothing operation ended up allowing it to finish the toolpath. Thankfully no tools or parts were broken, but it would be nice to find the main issue of the stoppage.
