01-23-2017
08:24 AM
- Mute
- Permalink
- Report
01-23-2017
08:24 AM
Hello!
If your B axis is going in the wrong direction, you may need to change the machine configuration for your post process from -1 to 1 (or vice versa). You're looking a line like so:
Your other issues are probably related to trying to fix this issue by hand, so I would try fixing the machine configuration first, and then if you are still having issues, we'll go from there! ![]()
Best,
-Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the
Kudo button - If it resolves your issue, press Accept as Solution!Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Fusion
