in reply to: Steinwerks
Good morning!
Yes trunion on the table...
I am thinking I have a post issue the more I look into this.
My issues are "B" axis is going the wrong direction.
And for some reason my Z axis is 1/4 inch too deep in the minus direction. And Y axis is 1/4 inch to deep in the minus direction.
We do 5 axis work all the time. but we are using Surfcam and have a 5 axis post for it and it is all dialed in for us.
I have purchased my own personal seat of Fusion 360 Ultimate.
And I am giving Fusion a try with 5 axis. (One would think Ultimate would have a working 5 axis post for Haas TR mills)
I have verified every offset in the Haas. It is correct.
The 3 ways that I know how to do 5 axis is...
1) Is programing the part just like you would a 3 axis job with your origin where you decide to put it.
Then having your set up guy tell you the shift amount from theoretical center of rotation of XYZ axis to the origin on the part.
The post would prompt you to enter those shift values
Let the post do all the calculations and post out the correct code.
2) Is mimic exactly what you have going on in the mill. Part location to center line of rotation. And place your model exactly like that in Fusion.
And post that out .
3) IF you are lucky enough to have a Dynamic work offset machine then you can do this all right on the shop floor.
