daniel_lyall
in reply to: daniel_lyall
It's this bit where the problem is.
setMachineConfiguration(machineConfiguration);
// Single rotary does not use TCP mode
optimizeMachineAngles2(0); // 0 = TCP Mode ON, 1 = TCP Mode OFF
You need to change from 1 to zero where the red zero is, it's around line 171.
It what I was thinking it was I just put out a test and G94 has a feed at the end now, it should be fine after you change that bit.
Make sure you do a air test first.
It's something tormach should of known about, Unless the cam team did it they have a reasion for it to be set like that, Why they don't have A tormach machine to test with.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
