- Mute
- Permalink
- Report
I am having an issue getting my drawing to appear on my Set Up Sheet?
For some unknown reason I am not able to get my drawing to appear in my set up sheet. I was able to see my drawing when using an earlier version ... but now it does not show up. I did see a post from a couple of weeks ago and the problem was solved by removing the # character from the file ... I do not have any special characters in my file.
I have tried to run set up sheets for numerous processes and the same results for all. I have attached a sample.
I am using a Mac.
Derek Logan
- Mute
- Permalink
- Report
Hi @Anonymous
Welcome to the Fusion 360 online community! Thanks for posting.
It looks like you are experiencing an issue in which CAM setup sheets from Fusion 360 are not including a picture of your CAM setup.
One thing I've noticed about setup sheets is that they take a snapshot of the current position and orientation of the design in the Fusion 360 window for the picture. Is your design visible and centered in the Fusion window when you select "Setup Sheet"?
If that does not help - what program are you using to view the setup sheets? Are they being saved as .html files? I tested .html files in Google Chrome, Safari, and MS Word and the visuals all appeared.
Feel free to attach the part file in which this problem is occurring if none of this works - I am happy to continue troubleshooting!
Fusion
