gmdimarzio88
3095 Views, 2 Replies
Invalid G code error
I've been at a friend's shop lately helping him with his 2004 Haas TM-1. Everytime I post to it I get an invalid G code error in my safety block for G69. When I go into my alarms it says,
"310 Invalid G Code
G code not defined and is not a macro call. "
I'm not sure what the issue is. Any advice would be great. I'm using Fusion 360 btw.
Steinwerks
in reply to: gmdimarzio88
G69 is Rotation Cancel (from G68) and is an issue that is expected to be fixed in the next update. Basically this means that the machine does not have the Rotation & Scaling option.
Brought up first in this thread: https://forums.autodesk.com/t5/computer-aided-machining-cam/g69-on-post-on-haas/td-p/6752769
This post should have the corrected code: http://cam.autodesk.com/posts/?p=haas
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
gmdimarzio88
in reply to: Steinwerks
Thanks for the help. I was confused since I ran this same code on a  minimill of the same age with now issue. Thanks again!
