EdDRM
in reply to: mike.tessier
Hi Mike ,
Windows 10 PC
In the past the setup sheet would go to Google Chrome then get saved in some unknown place and that worked for a some except if I didn't make a hard copy they where extremely hard to find .
I changed the location of where it was saved so I could find it and that worked off and on for a while.
Then that would save one setup sheet then give a message of http://forums.autodesk.com/t5/computer-aided-machining-cam/setup-sheet-quot-your-file-was-not-found-... when I tried to make a second one of a different setup .I fixed that by switching to Microsoft Edge browser which has worked up until today.
I had the setup selected that I wished to produce the sheet for and also had the the part on the screen in the position I wished to see on the setup sheet...yes the triad was there.
See attachment for the set up sheet that was produced.
thanks for the reply,
Ed
