Paul,
Thanks for the help. Obviously the solution takes a little work around step, but it works, and I got what i needed. Good thinking.
I'm still learning many of the fusion 360 utilities, but I think I'll work on a suggestion to submit to the Ideastation.
In my mind, having used the mobile app just briefly, it seems that when you open a design in the mobile app under the "Designs" menu there is a display for the model and your "setups"; it seems to me that under this menu or in the individual setup's "properties" tab, the default post could include the setup sheet.
But for now, problem solved. Thanks
Matt
