- Mute
- Permalink
- Report
Thanks, Scott and Fred. One another option you can use for copy existing operations is Store As Template commond when you right click on some operations.
Using this command, you can save all the settings in the selected operations except for geometry input as template and then you can use Create From Template command (when right click on a Setup or Folder) to create new operations with the same parameter settings, even in another design.
If you enable the cloud library function in Fusion (please see picture below), the template will be stored to A360 drive by default. Otherwise, the template will be stored in local disk.
For the error message about rest tool, I suppose you are using the Rest Machining option in 2D Pocket operation. The reason for it should be that the first 2D Pocket operation has removed all the materials and the rest machining operation with the tool you used for it don't remove anything more. If there is really some material left from the first 2D Pocket operation, please try to use a smaller tool in the rest machining 2D Pocket operation.
Hope these are helpful and any more questions please just let us know. Thanks for being a Fusion user!
Debbie
Debbie Lou
Sr. QA Engineer for HSM CAM
Fusion
