Hi Craig,
I replied to your post yesterday, but it seems to have disappeared. I'm also using a benchtop mill with manual tool changes. I've been using SheetCAM for the last couple years. I use the Mach Standard Mill screenset which has functions to measure TLO on the machine. Personally, I think it's easier to let MSM measure and store the TLOs than to have to measure them and put them into Fusion.
I requested an updated Mach3 post and Autodesk jumped on it immediately. This post inserts the G43 Hxx command right after the M6 Tx command. It does not allow a Z command on the same line as the G43 and it turns off the spindle before the G28 moves at the end of the program.
http://www.hsmworks.com/files/post-request/download/post/?key=9103608deb0708085459ec9233631bad
Good luck,
Chris
