LibertyMachine
For the most part, post processors for one program are typically incompatible with other platforms. One exception to this statement is the HSM line of CAM products. Inventor, Solidworks HSM and Fusion 360 all share the same kernel. Between the 3, you can share posts.
You have proven programs, and that is a huge step forward in sorting you out.
For starters, I'd encourage you to use the generic Fagor post that ships with Fusion. Yes, there are going to be slight differences in the format, but it might be very close to what you are looking for. If it gives you alarms and such, note carefully what they are and on what line it occurs.
If there are notes on one line but you want it on another, that's simple enough and purely cosmetic.
You want to make sure the meat of the program is proper.
Post out a SIMPLE job with the Fagor processor and attemp to run it. Note all errors. Mark up the code with RED text indicating added lines
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
