kevin.mcnally
775 Views, 4 Replies
Tinyg chilipeppr 2011macbook pro: job stops midway through
Hi there,
I'm cutting simple contour operations in plywood using the system indicated in the
Subject. This also uses a JSON server to communicate to the tiny g.
My CNC machine will stop suddenly toward the end of what was otherwise a
A successful cut. I have a feeling this is a memory issue.
Given the fact that I am cutting plywood, are there any settings I can adjust to
Make my gcode less heavy? I have heard that fusion 360 is configured for met
Metal by default which apparently requires more memory.
Also can someone explain how the gcode changes based on the type of process that is
Posted for various controllers? For example what's the difference between the tiny g
And the gcode for a shopbot?
Many thanks for help you can lend!
Kevin
