311 Views, 3 Replies
two objects different plane
Hello, I'm trying to generate a 2D toolpath on a part.  The perimeter of the part does not have a continuous edge, see pic below.  I can use the alt pic method to select all the edges, but for some reason it does not make a continuous path, it makes one for each plane.  How do I get the edge of the upper contour to drop down to the lower plate so its all one continuous path?
Walt
