xander.luciano
1282 Views, 1 Reply
QUICK TIP: Adaptive Facing - A constant engagement facing toolpath
Hey Guys!
Personally, I love the Adaptive clearing strategy, especially 3D adaptive. Whenever I need to face a part, instead of using the facing operations, which by default does both climb and convention milling, or wastes times rapid-ing back and forth, I use adaptive. It's super easy to set up, it looks awesome when you're running it (especially with large facemills), and it's constant engagement.
Here's a quick video [1:30] on how I set up an adaptive facing operation inside Fusion 360.
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Is there a way to use chip thinning option in 3d adaptive facing?
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
