LibertyMachine
in reply to: brittf
Using the generic Mach 3 post, it failed for me as well, but the message if gave was: Coolant Mode not Supported (or something to that effect). Looking at your selections, you had "Air" as the coolant option. The Mach post is not setup to use that code, although I'm sure it could be added.
Switching it to "Off" or Flood coolant allowed it to post out without an issue
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
