Turning on Stock Contours and limiting the height to that first surface should get you what you are looking for
EDIT: I see that you have Stock Contour turned on, but you've selected the areas you are cutting. This is incorrect. Stock Contours is typically for the overall size of material or area you are cutting so the tool "knows" where it's allowed to go for clearance and whatnot. It also gives it calculated surfaces to mill out to. I'd think you would just leave it to no selection, but turned on.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
