10-13-2016
03:10 AM
- Mute
- Permalink
- Report
10-13-2016
03:10 AM
I fixed up the groove. You needed to select the bottom edge of the groove instead of the top edge. Also make sure you have the tip alignment set properly. I changed it to "Tip" instead of "cut thru"
As for the chamfer with part off tool . I believe the chamfer operation is designed to work where there is no chamfer modeled. Since your part has the chamfer modeled this operation will not work properly to my knowledge. I know that part off with chamfer tool is in the idea station.
Fusion
