10-09-2016
06:25 PM
- Mute
- Permalink
- Report
10-09-2016
06:25 PM
what you wont to do then is do a offset sketch out from the model say cutter diameter + 1/2 cutter diameter again have the sketch at the top of the part and leave it turned on.
then when you select the toolpath you select the contour and the sketch and have the toolpath stay inside the line then the Adaptive will cut between the contour and the line.
if you wont a screen cast for this can you post your model it will make it easier to show you that way
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
