- Mute
- Permalink
- Report
can fusion use tools over 99 tools I am helping someone who has tools in the 100 + range if we post tool 99 it's ok if we post tool 100 fail city
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
- Mute
- Permalink
- Report
What post are you using? I just tested the Mach post and it should work up to 256, I tried tool 125 and it worked fine.
Here's the code in mach3.
if (tool.number > 256) {
warning(localize("Tool number exceeds maximum value."));
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
Looking in the Fanuc post it's set to 99. Look in onSection for the code above and change to whatever the highest tool number you need.
Mark
Mark Hughes
- Mute
- Permalink
- Report
@HughesTooling I am use my Y 4th axis post I changed the number from 99 to 999 still fail with tool 101 tryed 299 fail, 256 fail. that's why I ask it should work but fails.
I am going to try with the 3 axis mach3 post it's fine this way.
I am going to do a compare with the 3 axis Mach post and the 4th axis version, see if I can find what's wrong
Thanks Mark
Daniel Lyall
The Big Boss
Mach3 User
- Mute
- Permalink
- Report
this is the error log
Information: Configuration: Mach3Mill with A-axis
Information: Vendor: HSMWorks ApS
Information: Posting intermediate data to 'C:\Users\Daniel\Desktop\4th test.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, September 30, 2016 10:26:17 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41078
Configuration path: C:\Users\Daniel\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts\mach3mill Y axis.cps
Include paths: C:\Users\Daniel\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
Configuration modification date: Friday, September 30, 2016 10:25:02 AM
Output path: C:\Users\Daniel\Desktop\4th test.tap
Checksum of intermediate NC data: 1fd51770719048ad19fba8707cfef0e5
Checksum of configuration: eb70df5496598484ae29373914ce8375
Vendor url: http://www.hsmworks.com
Legal: Copyright (C) 2008-2012 HSMWorks ApS
Generated by: Fusion 360 CAM 2.0.2377
Error: Length offset out of range.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, September 30, 2016 10:26:17 AM
Post processing failed.
Daniel Lyall
The Big Boss
Mach3 User
- Mute
- Permalink
- Report
@HughesTooling thank you mark but how silly I found the problem the post did need changed for the tool amount number.
Here is the problem I had to change the length offset and diameter offset to 0 for it to work with the 4th axis post the 3 axis post it did not need changed. so that is what I need to find in the 4th axis post but got it going for now.
Daniel Lyall
The Big Boss
Mach3 User
- Mute
- Permalink
- Report
the solution to this was change the tool amount and the tool length amount from 99 to 256, the updated post's are here.
http://forums.autodesk.com/t5/computer-aided-machining-cam/mach3-4th-axis-s-files/m-p/6596091
Daniel Lyall
The Big Boss
Mach3 User
Fusion
