mwoodzork
998 Views, 5 Replies
Rotating indexer 90 degrees
I am using a Shopbot PRS Alpha with indexer to create 4 sided blocks with intricate patterns on each face. I have modeled the block in Fusion (excellent modeling tools) and gone through the many posts on 4th axis rotation but seem to be getting code that makes no sense.  I expect to see an M5 command somewhere in the code to tell the indexer to rotate 90 but there is no M5 command. I have checked 4th axis in the post processor dialog so i am puzzled that there is no m5 command.
Is there anyone with experience using the shopbot indexer with Fusion?
