mailZWX5Y
1360 Views, 16 Replies
Deep drilling ignores retract feed rate??
I'm wanting to use a drill op to run my auto-reverse tapping head, the code seems to make sense, it needs a dwell before retract to allow the clutch to disengage before reversing, it also needs to reverse at a slightly faster rate. Using a 6mm tap with 1mm pitch for example i have set a speed of 500rpm, a feed of 500mm/min and a depth of 5mm, so it seems it will thread in ok and then do the dwell, but then it retracts at G0 rapid and not the retract rate i have set of 550mm/min, this will snap the tap off on the way out.
Is there a reason the "Deep Drilling, Full Retract" cycle ignores the retract feed rate??
Can it be fixed?
The first block is the actual code and the second i have edited to be what i wanted to see..
(DRILL2)
M5
M9
T10 M6
S500 M3
G54
M7
G0 X0. Y0.
G43 Z31. H10
Z6.
Z2.
G1 Z-5. F500.
G4 P4.
G0 Z6.
Z31.
(DRILL2)
M5
M9
T10 M6
S500 M3
G54
M7
G0 X0. Y0.
G43 Z31. H10
Z6.
Z2.
G1 Z-5. F500.
G4 P4.
G1 Z6. F550.
Z31.
