rumpelstielz
in reply to: kb9ydn
many thanks @kb9ydn yes you can download the file from this thread: http://forums.autodesk.com/t5/computer-aided-machining-cam/how-to-avoid-stock-collisions-can-t-seem-... if you don't mind so i don't have to upload it again, it is linked to the initial post and inclides all the CAM operations you see in the screencast above.
will be interesting to see if you also get the garbled display in fast mode.
For the the framerate in standard mode it's especially laggy when you select several operations to be previewed, it's less critical when only previewing single operations. But previewing several operations in context has becom essential for my workflow over the years so the workaround of only previewing single operations is really only a crutch.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
