rumpelstielz
in reply to: rumpelstielz
hi again, i'm still really struggling with this, could maybe someone from the Fusion team comment.
Reading back over my initial post i'm afraid that it probably sounds a bit hostile, this was not my intent, i really love Fusion and fully understand that it's a complicated new product which will take time to mature. However this issue is becoming a major slowdown in my workflow now that i am starting to switch all my machining to Fusion and am tackling more complex projects. As much as i love the CAM features in Fusion these graphics issues add many unneccessary hours to my weekly work and makes it incredibly tedious to work and i really need to find a solution to this or at least know that it will be resolved at some point.
So maybe let me rephrase my question: what can i do on my side to alleviate this?
would another graphics card help, is Fusion not meant to be used with mid-leve graphics cards like mine, is it more geared towards pro cards in the 1000$+ range ?
Is there maybe an issue with this particular graphics card and another make/model wouldn't have these issues ?
Or would an AMD card offer better performance ?
I'm assuming that the CPU is not much involved with the simulation framerate but if it is would upgrading my i7-2600k (which is a couple years old) to a more recent i7 or a Xeon help to improve performance significantly ?
Is there anything else i could do ?
Someone suggested that the bad performance i'm getting is due to the fact that i use very small vertical stepdowns in my operations,unfortunately that's not something i can change at the moment, this is all my machine can handle for now and i have neither the budget nor the time to acquire a new CNC.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
