bdrmachine
112 Views, 2 Replies
Controlling cut depth
I have a oval part being cut from round stock that is slightly larger than the major diameter of the part.  I don't want the tool more than 50% engaged in the part while cutting the narrow part of the oval during the first time around the part.  I can manage that by adding 6 step-overs to the roughing pass but after that first pass when the bar stock is close to oval every following pass the tool is barely engaged.  What is the best way to handle this first pass and remove more material on following passes?
