- Mute
- Permalink
- Report
@blackbearcustomkydex wrote:
It requires zero code or files to contemplate the issue
I tend to disagree with that sentiment, as a LOT of what happens in the MFG environment is entirely subject to the settings that the user decides to go with. What you are seeing is not always what someone else sees. If you do want assistance on this forum (and we do certainly want to help), could you share a sample file that shows what you're seeing? Of course, if you just want to moan about the product and support, you're also welcome to do that ![]()
As an example; if I was to have an "Ignore Stock Less Than", I would expect different results in some areas, or if I had my default values (which you can change and capture) for Min Stepdown, that would also give me different results in other areas. It all comes down to "what are all the values in one toolpath", which we cannot know without seeing detailed screenshots or a simple file that captures that data
Seth Madore
Fusion
