   Hello Thank you for the reply. Here is the link https://a360.co/48Lo3us . I do understand to pick entire model the link here is just a simple slide entire model is picked to Avoid Surface (Red) and the (Green) is Set to "machine surface" and we end up with toolpath waterfalling over edges even with "Contact point Boundary and Contact only" Checked and also unchecked either way tool path still falls over this stands true for all other 3d toolpaths now.     If you guys have access to the old way please pull this slide in and program a parallel pick machine surface and you will see the results.
     One other thing to consider is this is just a simple slide. When programming large molds such as large headlight lenses with many many multi faceted surfaces each time you are picking the entire model to add to a toolpath we are slowing processing time down.
