Thanks for the further details tommyscustomshop. I recognise that the previous workflow was simpler and that had value. Your concern is noted. It does sounds like you are still doing more work in the machine avoid table than you need to. As CRANDALLPRECISION points out, you do not need to click on loads of avoid surfaces. Simply set the model group entirely to avoid (see attached picture).
I am still concerned that I don't understand the 'waterfall' effect you are seeing in the toolpath. If you could send me the f3d, we could check whether this difference in toolpath behaviour is by design, or if it is a bug.
Tessa Colledge
Senior Software Engineer
