Yes, it is more work up front as it works more like other software so you can have multiple surfaces with different amounts of stock to leave in the same toolpath. When you create the toolpath and go to the touch avoid part just right click on it and edit it to red(avoid) now create hit the plus and pick the surfaces you want to cut(green). I attached a simple sample
