Thanks Andrew.  This is the first time I attempted to use the reduced feed rate while ramping.  I was not aware that it does not affect the ramp feed rate.  In this example, I probably can get away without using it at all, I was just trying to optimize my feed rates.
If I reduce the feed rate for ramping, I will not be able reduce the feed rate while moving around the radius.  It will reduce the feed rate for the entire tool path.
Thanks... Richard
