10-23-2024
05:54 PM
- Mute
- Permalink
- Report
10-23-2024
05:54 PM
In the example below, I programmed a reduced feed rate of 2.9 IPM. My goal was to slow down the feed rate as the 3/16 end mill turned the corner. In the past, the tool path for the reduced feed rate was shown in yellow. I can see the yellow reduced feed rate at the bottom of the tool path, but why are the other similar corners still showing red?
Thanks.... Richard
Fusion
