Hiii @AndyDHarlow ,
I have worked on proper solution for you. Kindly refer this and make the necessary changes to your post. Kindly undo/remove all previous changes mentioned above from Post.
Update the getfeed Function as per code below.
function getFeed(f) {
  // This lime of code makes sures that value is passed on s_Spindle in case of Part Transfer
  //START--------------------------------------------------------------------------------------------------------------
  var s_Spindle = spindleSpeed;
  var strategies = ["turningSecondarySpindleReturn", "turningSecondarySpindlePull", "turningSecondarySpindleGrab"];
  if (strategies.indexOf(getParameter("operation-strategy")) != -1) {
    s_Spindle = cycle.spindleSpeed;
  //END---------------------------------------------------------------------------------------------------------------
  _f = (currentSection.feedMode != FEED_PER_REVOLUTION && machineState.feedPerRevolution) ? f / s_Spindle : f;
  if (activeMovements) {
    var feedContext = activeMovements[movement];
    if (feedContext != undefined) {
      if (!feedFormat.areDifferent(feedContext.feed, _f)) {
        if (feedContext.id == currentFeedId) {
          return ""; // nothing has changed
        forceFeed();
        currentFeedId = feedContext.id;
        return "F=R" + (firstFeedParameter + feedContext.id);
    currentFeedId = undefined; // force Q feed next time
  return feedOutput.format(_f); // use feed value
 Also remove the below line of code from these cases    case " secondary-spindle-grab"case "secondary-spindle-return" and case "secondary-spindle-pull"
writeBlock(getCode("FEED_MODE_UNIT_REV")); // mm/rev    ##REMOVE THIS LINE
 and Replace with the code below :
gFeedModeModal.reset();
writeBlock(getCode("FEED_MODE_UNIT_MIN"));
Note : Take care about the positioning of "G94". Adjust to it as per requirement.
