Ks-bart
in reply to: seth.madore
 hi @seth.madore ,Another issue is when you select "use chip thinning" togheter with "order for shorter links" the direction "climb milling " is no longer valid!
So with multiple passes, the first pass is climb, second conventional, our mills really don't like this :winking_face:
